730 diesel still no power
mark
06-26-2004 20:25:24
my 730 diesel, fresh rebuild when we bought it. i went thru several checks to find problem. so far i have completed these items; changed fuel filters,clean oil bath, checked air intake to make sure it was clear, put fuel pressure guage on it and it has 26 t0 30 psi,went thru and checked the timing its on. NOW WHAT????? still dont have the power, fuel injectors ?? any ideas stumped
Clooney
06-28-2004 03:39:00
 Re: 730 diesel still no power in reply to mark, 06-26-2004 20:25:24
Mark, only a few things will cause a diesel to lose power..
1)- Compression,, if the compression is low it will be low on power & start hard.. If possible borrow or make an adapter to test your compression.. It wouldn�t hurt to check the compression release for proper adjustment as that can cause low compression or improper valve adjustment..
2)-Fuel delivery,, you need good primary pump pressure [it sounds like you have that] & good working properly adjusted pumps with good clean injector tips. Use a mirror & check your rack settings & MAKE SURE the rack will move to full throttle [if that was taken apart on the rebuild it might not be moving to full throttle]. You might also want to plumb the return line into a remote glass jar or plastic jug & look for excess air in the return line [that means your system is sucking air from somewhere]..
Try removing the injectors & turning them around [don�t worry about the bleed-off lines [just let them hang open], then crank the engine & look for a good spray pattern with no sputtering or large droplets. Also watch for the spray to increase as the fuel lever is moved to wide open [CAUTION: DON�T use your hand to test the spray pattern as that system can inject the fuel right through your skin,, use a piece of paper]..
3)-Plenty of air,, it sounds like you have already tried the oil bath but there is a wire mesh above that that can plug as well as the intake snorkel out the front.. Try running it with the air intake/air cleaner removed completely [that will eliminate all the air intake as a problem]..
~If your cam was installed out of time it could also cause a lethargic engine so it wouldn�t hurt to check the valve timing vs. crankshaft position..
~One last thing MAKE SURE your flywheel is installed on the crankshaft correctly [especially if you have a taper lock flywheel]. If that flywheel is off a spline or two all your injector settings & compression release settings will also be wrong..
*If you have good compression, properly timed & good spraying injectors, & it is getting a good air supply- it should run good & have plenty of power [so what doesn�t I have?]..
[email protected]
JL
06-27-2004 17:55:19
My 730 diesel couldn't keep up with the others at the pulls. Ended up having the pump rebuilt (now has 30 psi, 15 before), injectors needed rebuilt as they were just peeing out fuel instead of "cracking", and had the head checked out at a local machine shop. Dyno tested different timing settings, stock was best by far. Front of the pack at the pulls now, and all we did was make sure everything was up to specs. I agree with TPat, check them injectors, and make sure your throttle linkages are working right. Hope this helps.
TPat
06-27-2004 11:31:50
I had a 720 diesel that lacked adequate power. I had the injectors cleaned and pop tested at local shop. I put the injectors back in the tractor and it simply performed like a different tractor. The two cylinder diesels perform well when running as they are designed to. Good luck, don't get too frustrated, you will work it out. Your transfer pump pressure is good !! You may need to have your pump rack checked at a pump shop?? Keep posting your progress. There are many knowledgeable JD Diesel Mechanics that post on this site.
buickanddeere
06-26-2004 20:48:46
How many HP does it show on the dyno, what is the fuel rack setting and what colour is the smoke. What type of a mechanical sound is heard down by the cylinder head at idle and full power?
