HELP! on 4010 rockshaft problems after transmissio
gwece
06-25-2004 18:36:49
I just pulled the rockshaft and replaced the transmission pump on my 4010 diesel. After starting the tractor, the rockshaft would not raise until I put it in the "down" position. Would not lower at all until I removed the pin from the valve operating lever and moved it manually. Do I need to remove the valve assembly and retime, or can I loosen the quill and move the outer sector gear a bit at a time to fix, or do I need to do something else??? Any advice offered would be greatly appreciated! Thanks!!!
Jim B
06-26-2004 04:12:32
 Re: HELP! on 4010 rockshaft problems after transmi in reply to gwece, 06-25-2004 18:36:49
gwec,when installing rockshaft on 4010 there is a part coming up from bottom that has to be lined up with rockshaft valve linkage so your rockshaft will work.If you missed getting it back right rockshaft will not work properly.Jim B
Bob
06-25-2004 22:34:59
It's been a while since I've messed with the 3-point on one of these, but one thing comes to mind. There is a spring steel shaft across the bottom of the rear end for draft sensing, and there is a "fork" that hangs down from the 3-point mechanism, and straddles that lower shaft. Did you happen to be far enough into the rear end that you dislodged that fork from the shaft?
Before I adjusted anything, I'd look closely for anything I bent, damaged, or miss-assembled. You say the system was working, unless something has changed, it should still work, and if you try to adjust things without the proper service tools, likely things will get worse before they get better!
Clark
06-25-2004 20:22:09
Keep in mind I don't know anything about what you are doing. I'm just reading from the I&T manual:
There is a section on control valve adjustment. This take some special JD tools. After valves have been adjusted they re-install the housing covers and valve springs. Install and time the operating link arm, valve operation lever and sector gear. The linkage is correctly timed when pin on operating link arm and the cast pointers on housing and operating lever are aligned (there is a picture in the manual, sorry no way to get you this.) Tighten lever quill securely, install cam follower link and spring then install valve housing. After assembly is complete, move selector lever on rockshaft housing to lower (D) position and attach control cable. Start engine to see that rock saft moves to full rasied and full lower position when dash control lever is moved the full lenght of the quadrant. This is what was in the manual (I&T Shop Service Manual #JD-203). Hope this helps - Clark
gwece
06-25-2004 20:57:55
 Re: Re: HELP! on 4010 rockshaft problems after tra in reply to Clark, 06-25-2004 20:22:09
Clark:
Thanks for the info. That's about what my JD Shop Manual said to do. When we removed the rockshaft we did not remove the valve assembly but I think we turned the control valve lever or someting and got it out of time. I was hoping there might be an easy way to readjust without taking the valve assembly off, but I guess not. Thanks for taking the time to look it up in your IT manual.
gwece
gwece
01-27-2005 07:46:01
 Re: Re: Re: HELP! on 4010 rockshaft problems after in reply to gwece, 06-25-2004 20:57:55
url posting test
