730 shifting problem
Mel
06-25-2004 18:25:33
I have a 730 that I can shift ok on one side of the quadrant but I can't move the lever over to shift the other side. I have taken the cover off, the slots seem to line up. you can move the overdrive shifter back and forth if you hold the lock up. If I move the overdrive shifter to one side I can shift those gears but can't move it back to the other side. The repair manual shows a picture of it and mine looks the same as far as I can tell. If anybody has any ideas as to the problem I would appreciate the help. Thanks ahead of time.
Hilltopper
06-27-2004 16:52:39
 Re: 730 shifting problem in reply to Mel, 06-25-2004 18:25:33
I had the same problem with my 720d It was very hard to get into overdrive. I decided that the shifter lever was not coming far enough down to unlock the overdrive so it would shift. It worked fine with the Quadrant removed. I decided to take a grinder to it an cut out the quadrant at the bottom so it would unlock the overdrive lock. I ground it at an angle similar to the angle of the shifter. I took off about 3/32 at the top of the overdrive slot and it solved my problem.
