How to bleed brakes on 3020
Clark
06-25-2004 17:39:45
I have a 1966 3020 that I had to do some work on the brake valve. I need to bleed the system after re-installing. The manual shows a bleed screw that is loosened then acuate the brakes. However the tractor has a differential lock so where the bleed screw is suppose to be is the pressure oil to differential pipe. Since the bleed return passage is internal what do I have to do to bleed the system? Thanks for the help.
Clark
JimKS
06-25-2004 20:13:42
 Re: How to bleed brakes on 3020 in reply to Clark, 06-25-2004 17:39:45
You can bleed the brake valve using the bleed screws for each side kindof above the final drives and a bit to the rear- the brake valve doesn't have to be bled right there at the valve. Have somebody hold each brake down while the tractor is running, break loose the bleed screw and let the oil run through it a minute or so, then do the same on the other side. The air and oil will bleed back into the case.
