JD 4010: Hydraulic Problems
Trey Nichols
06-25-2004 07:24:53
My JD 4010 is having problems with the hydraulic system. The 3-point and remote cylinders are both slow and barely responsive. The power steering and brakes are effected as well. Sometimes everything works fine (usually when it first cranks), but after it gets hot, I can't lift anything. When the problem first started, I heard a humming noise coming from up under the dash. I changed the fluid and filter hoping to fix the problem, but still no help. Someone told me about a high pressure check valve that might be wore out and not allowing pressure to build up in the system. Could this be my problem? If so, where do I find it? What are some other ideas to check? Also, my starter has quit working. It doesn't even click anymore. What could be wrong with it? Any help would be mostly appreciated.
Jim B
06-26-2004 04:39:26
 Re: JD 4010: Hydraulic Problems in reply to Trey Nichols, 06-25-2004 07:24:53
Trey,could be internal hyd.leak.Humming under dash/steering or scv's.Jim B
DON
06-25-2004 07:40:39
THE STROKE CONTROL VALVE IS WHAT YOU ARE LOOKING FOR. ITS IN THE FRONT PUMP IN THE END CAP. THERE IS A PLUG WITH AN ADJUSTING SCREW IN IT, ITS UNDER THERE. YOU WILL HAVE TO TAKE THE PLUG ON THE OPOSITE SIDE OUT IN ORDER TO DRIVE THE OLD SEAT OUT. OBSERVE CAREFULY HOW IT COMES OUT SO YOU CAN PUT IT BACK THE SAME WAY.
