2120 PTO
txblu
06-24-2004 07:05:22
Helping a neighbor.
He has a 60 hp 2120 with single 540 PTO transmission driven (Not LIVE, nor Independent).
He was bush hogging and high centered a few times and stripped his PTO drive.
With the PTO disengaged, the shaft free wheels as was before.
But engage the PTO lever, with the tractor off and the clutch released you can spin the shaft and as you spin it you feel and hear this thunk thunk thunk like he stripped a spline to something.
I have the IPB but I can't figure what connects the output shaft to the mid shaft. The only thing in the area, where the 2 shafts go together is a very large gear that is splined to one of the shafts. Don't know if it's job is to slide over the interface of the output and mid shafts. If so, what are the teeth for?
Help appreciated. Would like to try to fix without split as have no resources to split tractor.
Thanks,
Mark
david val
06-25-2004 04:23:29
 Re: 2120 PTO in reply to txblu, 06-24-2004 07:05:22
i am not sure i completely understand your post. if the pto is 540 only, there are splines in the pto collar (operated by the lever above the left footrest). these are very unlikely to strip. there may be a problem of partial shift due to linkage problems (usually a roll pin that connects the lever to the inner mechanism falls of, may be repaired without spliting after removing the rockshaft housing). another possibility is stripped pto gears. it's very unlikely. another possibility is bad pto clutch disk. you can check it by iluminating the clutch through the opening in the clutch housing. have soneone rotate the pto. if you see the shaft rotating at the clutch, then the clutch is bad.
in the 540/1000 pto, the pto end shaft is bolted to the pto shaft. in this arrangement, loose bolts may create the prtblem you post about.
david
txblu
06-25-2004 06:28:05
 Re: Re: 2120 PTO in reply to david val, 06-25-2004 04:23:29
I looked at the 3 types of PTO's in the service manual and this makes the least sense. What doesn't make sense is how does the output shaft spline connect to the driving mechanism. The only thing that I can see that could provide that function is the PTO gear
I'm a blue guy and don't understand green, only did an inframe on a 4020 engine.
In this tractor, does the clutch you mentioned drive a shaft other than the PTO shaft (along side of it)and on that shaft is a gear that meshes with the big gear shown in the PTO parts breakdown?
If so this says that the whole PTO shaft (from rear quill to front quill) is driven from a gear, not driven directly from the front shaft sticking in the clutch disc.
Last, how much can you get to from the rear; drain the fluid, pull out the PTO shaft and what else without having to do a split?
Thanks,
Mark
david val
06-26-2004 06:35:31
 Re: Re: Re: 2120 PTO in reply to txblu, 06-25-2004 06:28:05
the pto clutch (non independant pto) turns a holow shaft splined to it. the other end of the holow shaft is a small gear (there's another gear on this shaft in 540/1000 pto). this gear is in mesh with a large gear which is splined to the front pto shaft. on the rear end of this shaft a shift collar is splined to the shaft. the rear pto shaft (which is what you see outside the tractor on 540 only pto)has splines in it's front end, which is very close to the front shaft. when you shift the pto with the shift lever, you slide the collar to the rear and the splines in the collar mesh with the rear shaft splines and connect the two shafts together.
it's important to know the type of pto on this tractor. live or independant, 540/1000 ot 540 only. in independant pto the operating lever is between the gear shift levers. in 540 only pto the shaft comes right out of the rear quill, on 540/1000 pto the shaft is bolted.
david
MITCH
06-24-2004 11:56:50
HEY MARK, I'VE ALSO GOT A 2120 JD, GOOD STRONG TRACTOR, I'VE GOT A SERVICE MANUAL FOR IT, IF YOU NEED ME TO SCAN YOU ANY OF THE PAGES LET ME KNOW
txblu
06-25-2004 06:15:44
 Re: Re: 2120 PTO in reply to MITCH, 06-24-2004 11:56:50
Thank you very much sir. The owner had one.
Mark
