Grade 8 Machine Bolt For Flywheel
720Deere
06-23-2004 16:16:21
I have been in search of grade 8 square head machine bolts to no avail. It seems that they are only made in grade 2. Has anybody else just used hex bolts for the flywheel? This is for my 720 diesel. It has a good original flywheel and crank and I want to keep it that way. I don't know what the bolts are that I took off, but they don't look like grade 8. Any input would be appreciated!
Clooney
06-23-2004 17:53:39
 Re: Grade 8 Machine Bolt For Flywheel in reply to 720Deere, 06-23-2004 16:16:21
third party image
720Deere, I have always just used hex head grade 8 bolts with hardened washers & hardened nuts.. NEVER had one ever come loose using those.
~In using standard bolts you have a couple of choices, The first is to use a wrench to hold the hex bolt end while you tighten the nut.. The second is to use your welder & add nib [drop of weld] to the bolt hex head.. That will be enough to keep it from turning while you tighten it.
~No matter what you use be sure to not over tighten those bolts- [Caution: don�t over tighten as those grade 8�s will allow you to over tighten before stretching sets in.. If you lubricate the threads the force goes up for the same torque so if you lubricate back off on the torque a little].. I usually go about 300�# - 325�# dry on those diesels [or about 280�# lubricated]..
~Tighten the bolts, then run the tractor for a couple of hours & re-torque,, then run it for a few more hours & re-torque again.. Then run it until the next oil change & check the torque again, if it is holding you won�t have to ever worry about it.
See picture for an over torqued diesel flywheel bolt..
[email protected]
John T
06-23-2004 17:01:07
720, I just did a quick search and look (got a Lions Club Meeting tonight) but it appeared these places had square head bolts in Grade 8??
Link
Link
Link
Link
John T
