4840 vs. 4640
Ted
06-23-2004 13:38:15
I am looking to buy either a 4640 or 4840. I was wondering any pros or cons to either? Is the 4840 bigger in size than the 4640? Thanks for any information
best condition
06-25-2004 00:08:21
 Re: 4840 vs. 4640 in reply to Ted, 06-23-2004 13:38:15
Buy the best condition one of either model. The differences are minor.
Jarrod
06-23-2004 19:51:53
4840's are more prone to cylinder block counterbore problems because their block isn't heavy enough for the amount of horsepower it puts out. Front pivot pins/bushings because of extra weights and also rear wheel bearings but that goes for about any tractor. Both are real popular in this neck of the woods. (KS)
leland
06-23-2004 19:09:39
What kind work are you going to do? both are 150 to 180 hp tractors so look around were i live acutions prices are about $12000 $ 22500 depending on cond so shop carefully and you will get a bargain . hint go to auctions when its -25 and you get a bargain mostdays .
ted
06-24-2004 15:15:53
 Re: Re: 4840 vs. 4640 in reply to leland, 06-23-2004 19:09:39
the tractor will be used for an all around tractor. I already have a 4020 but need something bigger mainly for working ground, but also for an all around tractor. The 4640 would have enough power for my use, but I wonder if I should just get a 4840 since they cost the same. But I'm wondering if the 4840 is any larger in size than the 4640, since if the 46 is smaller it may be more versatille. Thanks for the help.
Ted
