J D A Shifter
Chuck
06-23-2004 08:07:38
Am working on a 1950 A with the 6 speed quadrant and am having trouble getting the shifters in the right position when I put the steering tower back in place. I seem to be able to get 1st, 2nd, 5th and reverse right, but none of the others go into gear. In fact, 4th appears not to be there at all. When I pull the tower up, I can manually bar them into all gears but 4th appears to be too far to the right to be able to do with the shifter in place? Any secrets as to where to start looking for the problem.
Pappy
06-24-2004 21:49:27
 Re: J D A Shifter in reply to Chuck, 06-23-2004 08:07:38
Just got through with a similar operation. Place all the shifters in neutral and be sure they are locked into the detent. Then, adjust the shifter shafts so that the gates all line up by adjusting the screw type adjusters on the left side. You can look at them and tell whats happening, but you need a service manual to clarify this more. Fourth and sixth are not adjustable as the set screw holds the shifter to the shaft.
