1945 jd b
dan
06-23-2004 06:56:31
This is my first green restoration. The carb has the letters dtlx on the casting. Does anyone know if there is a website on setting the carb? It is soaking now and I want to rebuild it this weekend. Thanks in advance for any information. Dan
Jon C
06-23-2004 08:40:25
 Re: 1945 jd b in reply to dan , 06-23-2004 06:56:31
Dan - There are several places that can help you with your carb. problems. "Burrys carbs" and "Roberts carb" comes to mind, and I think both have a listing of parts and specs. on their web sites. There are others too. (Type "DLTX" in a search engine.) I'm not sure about a 45 B, but I know the mid 1930 B's used a DLTX-10. Be carefull, as the "A" carb (dltx-18) will fit as well other DLTX carbs, but it won't run right. Also if its an "all fuel" or gas only, the carb is different. I have tinkered with several and finally figured out that puchasing a re-built was worth the money. (Carbs and mags must work well to have a good running B.)
dan
06-23-2004 11:36:00
 Re: Re: 1945 jd b in reply to Jon C, 06-23-2004 08:40:25
This is an all fuel b. The dltx is very clear in the casting. Wherer would I find the number to go along with the dltx?
Jeff
06-23-2004 11:40:55
 Re: Re: Re: 1945 jd b in reply to dan, 06-23-2004 11:36:00
The number is stamped right behind the letters altho sometimes it can be somewhat light. For a 45 B it should be a 34. I would have to agree that these carbs are kind of tricky even tho they look very simple. They have several tiny holes that must be cleaned out perfectly for them to run right. The fellow I had mine rebuilt at used an ultra-sonic cleaner, and then he always put them on his tractor and trial runs them to make sure they are good to go. I can give you the name of the guy that does mine if you want, hes very reasonable and does an excellent job.
Gaylord Miller
07-04-2004 16:38:57
 Re: Re: Re: Re: 1945 jd b in reply to Jeff, 06-23-2004 11:40:55
Hi
I recently aquired a 1945 Model B jd and have been having the same problem.Can I get an adress of the fellow who could do this rebuild of the carb??
Jon C
06-23-2004 12:30:54
Not only is Jeff right about the small orifices, but many times the lower spring is rusted away, and the brass nozzle in the center is a bear to get out without ruining, to clean up.
And even with heat and cooling, the small brass plugs in the side of the body can be a bugger to get out.
Finally just when you think you have done a good job, the tractor may only run fair, as there could be air leaks around the jet screws or you missed cleaning a passage. The money I initially saved doing my own, cost me hours and hours of time and frustration.
