720 D leaking axle housing
steve duplechin
06-23-2004 06:49:16
I have grease leaking from the rear axel housing. I need to replace the felt washer, but to do this you have to remove the outer felt retainer. This part is no longer available. Does anyone know of a way to get the retainer off without damaging it? If not do you know of an aftemarket outlet that would have the retainer?
Mike M
06-23-2004 07:11:15
 Re: 720 D leaking axle housing in reply to steve duplechin , 06-23-2004 06:49:16
The seals you need to replace are on the inside letting the housing fill up with oil. The felt retainers will pop out when you pull out the axles to get to the real problem area.
Clooney
06-23-2004 07:11:10
duplechin, first that felt washer isn't what holds the gear oil in.. There is an axle seal inboard next to the bull gears that must be replaced to stop that gear oil leak. All that felt washer does is keep the dirt & water out of the outer wheel bearing..
~When you pull the rear axle inner nuts & walk the axle out using a wedge & the inner nut to force the axle out the outer felt retainer will come out with [on] the axle without any damage..
~To get to those inner axle seals the whole rear of the tractor will have to be removed [it�s top heavy & awkward but not too difficult to remove]..
Any questions just post back or E-Mail..
[email protected]
