B JD Noise
B JDfarmer
06-22-2004 20:37:15
I have a 48 B jd i just bought. got it runnin have checked everything over. It has a grinding type noise when running. When u put it in gear and let the clutch out it has a little knock to it. it sounds like its coming from the crankcase cover one the flywheel side. Any thoughts of what might be causin this?
Clooney
06-23-2004 03:51:41
 Re: B JD Noise in reply to B JDfarmer, 06-22-2004 20:37:15
B JDfarmer, that grinding noise could be coming from many places. You probably have bad bearings somewhere or many places. Use a mechanics stereoscope or long screw driver & listen for the area the grinding is coming from.
~If you can give us as much information as possible on what gears the noise happens in & as much information as possible on when it happens we can guess the area a little closer for you..
[email protected]
