8630 Engine
Jeff A
06-22-2004 19:47:58
My neibor has an 8630 that he pulls a dirt pan with.This past spring the motor went down in it.It spun the number 2 rod bearing and broke the cam shaft.We were told that these motors were famous for this and would do it again if rebuilt. Is this true?Can he put a later model moter in it? I have also read that some people have repowered these tractors with a cummins engine.Is this feasable?Thanks in advance for the help.
leland
06-23-2004 19:17:21
 Re: 8630 Engine in reply to Jeff A, 06-22-2004 19:47:58
farmer i worked for had one and deere put a new 50s series motor in it. something about to soft of metal.just put a 855 cummins replacment motor they make kits that way you can put a 290 to 400hp engine they can be gotton at a bargain, old cummins are forsale ererywere goodluck.
Bob
06-23-2004 07:47:46
How many hours did the engine go before failing?
While not the best engine Deere has ever made, if the block checks out (No severe deck cracking, and main bearing bores in line and in spec), it should go for thousands of hours after a quality rebuild.
I have an 8630 that has gone 9000 hours WITHOUT a rebuild.
