1945 model b backfire
eric shoopman
06-22-2004 16:04:24
i was having problems with a weak magneto. I sent it out and had it rebuilt. I installed it the same way it came off and went to start the tractor. it is a hand start. i spun it a couple of times and it back fired. Very loud. I tried choking and turning down the throttle and back fired again. I am afraid to try it again, i don't want to damage anything. Could I have installed the magneto wrong? It only has two bolts and I hooked the same wires back up to the same place. Is there something inside I needed to turn?
thanks in advance.
eric
Buck
06-22-2004 17:36:06
 Re: 1945 model b backfire in reply to eric shoopman, 06-22-2004 16:04:24
Eric,
Right at the mag. just switch the wires.
When they worked on your mag. they rotated
it, so it is not the same as when you took it off.
To correct this just switch the wires.
Hope this helps,
Buck
