Decal removal
David
06-22-2004 12:47:32
I have a A JD with decent paint job, but someone used the cheap decal strip on the hood such as TSC sells. I want to remove the decals with out paint so I don't have to strip the whole hood. If I repaint, I can sand the existing paint. Any suggestions?
Clooney
06-22-2004 18:54:52
 Re: Decal removal in reply to David, 06-22-2004 12:47:32
David, as mentioned below a heat gun will usually work but on some stubborn decals the heat won�t always do the trick.. There is a special type pad to put on your DA sander specifically made to remove stubborn decals [I believe it is made by 3-M].. Try the heat & if that won�t work ask you local automotive paint store about a special pad for your DA sander..
[email protected]
Ray
06-22-2004 18:52:30
I've tried removing decals several times and haven't had much luck,usually they were put on
before the paint was completely dry,(sometimes
takes days),and they actually sink into the paint,so even if removed you can still see
where they were.
Henry J
06-22-2004 17:16:11
David
I also have had perfect results in taking the dealer decals off autos and pick ups by using a heat gun. Ya gotta watch out because it is much hotter than the hair drier and can get things too hot.
I usually work the heat and intermittently keep feeling the paint to make sure it is not too hot to touch. Use a finger nail and start a corner and they have always peeled right off. If some gunge is left a quick rub with polishing compound followed by wax if the paint is totally cured and walla.
This method comes with no warranties. Also depending on the type of paint and exposure you are likely to have a different shade under the decal, but hopefully the new one will cover it.
Good Luck
Russ
06-22-2004 18:49:34
 Re: Re: Decal removal in reply to Henry J, 06-22-2004 17:16:11
I use the same method exept just use a product called "GOOF OFF" to remove any glue residue..... "AFTER" the paint has cooled! And as always test an inconspicuous area first.
CLW
06-22-2004 13:55:48
David, I have used the wifes hair drier with good luck on a motorcycle. It has a lot to do with how long they have been on. Get an small area as hot as you can and try to peal it back very slowly as you keep the heat on it. Have not tried a tractor decal. We also removed the metal CHEVROLET strip from the tailgate of my sons 95 pickup that way when it was new.
CLW
