Dubuque Shifter Question?
Henry J
06-22-2004 10:54:46
I have a late model 58 420 and am in the process of piecing it back together. When looking at the parts picture I noticed a spring that fits on the shifter somewhere under the bell shaped guide.
My guide (three slotted shifter guide)has an oval hole toward the base on each side and a little over half way up on one side two slots about 3/4 inch long and spaced about 1/2 inch apart. I got lost in the book on how the spring goes in there. The original spring on mine had been missing from day one for me.
This spring must have some centering effect on the shifter?
I am going to order one if I can figure out how to put it in. Can someone tell me how this baby hooks in there and how it wraps/goes around the shifter?
Thanx
Mike M
06-22-2004 12:38:56
 Re: Dubuque Shifter Question? in reply to Henry J, 06-22-2004 10:54:46
My guess is it was put there to help hold it in neutral if bumped when getting on and off.
Johnnyputt
06-22-2004 11:30:39
The spring has a hook on both ends. Both hooks fasten in the two small slotted areas on the right side of the shifter guide. The spring wraps around the shifter keeping tension toward the right side when in neutral. Not sure what the advantage of that is really. We haven't put that spring on any of ours.
BMeyer
Henry J
06-22-2004 12:14:38
 Re: Re: Dubuque Shifter Question? in reply to Johnnyputt, 06-22-2004 11:30:39
Jhonnyput
Thanks for the reply. I was thinking that way but could not figure the logic of having a shifter tensioned to one side of the gate.
I am gonna leave mine loose also.
By the way. I made that tool/guage to set the cone angle up on the differential. I did put new bearings and races on both ends of the output shaft so that would make a little difference. It turns out that I was .005 off on the original shade tree method of putting it together. I am not too sure how much difference that would make in a slow turning differential like that, but it shoulda been done right the first time.
Thanks
