JD 1020 Stops running after it warms up
Victor Firkus
06-22-2004 04:25:28
My tractor stops running after it warms up. Any clues why? I have asked dealers and they have no clue. Help!
Mike M
06-23-2004 08:28:02
 Re: JD 1020 Stops running after it warms up in reply to Victor Firkus, 06-22-2004 04:25:28
Condenser and or coil may be bad.
Vic
07-01-2004 05:50:39
 Re: Re: JD 1020 Stops running after it warms up in reply to Mike M, 06-23-2004 08:28:02
I replaced the coil and condenser. My tractor has an "Anti-Dieseling Power Solenoid' on the carburetor. Which
get very HOT with just turning the key on and the engine isn't even running.
I did replace that part in 1997. The tractor only has 417 hours on it
since this part was replaced, is it common for that to go shot that soon??
David
06-22-2004 17:18:46
Have you checked your fuel filter?
Victor
06-23-2004 07:47:44
 Re: Re: JD 1020 Stops running after it warms up in reply to David, 06-22-2004 17:18:46
Yes, I put a new one in.
Garry
06-22-2004 11:12:02
Victor, I'm haveing the same problem on my John Deere M. I have replaced the coil, points, condenser, and plugs. My next check will be the fuel. I have heard that a cracked head will cause that but I havn't checked that yet since that is the will be my last option.
Mike M
06-22-2004 06:44:07
Gas or Diesel ????
Vic
06-23-2004 08:08:36
 Re: Re: JD 1020 Stops running after it warms up in reply to Mike M, 06-22-2004 06:44:07
It is a gas engine.
