3020 and 709 rotary cutter
Robert Barcus
06-21-2004 19:29:42
My thanks to all who gave me needed advice on my "new" 3020. Last Saturday, it ran flawlessly with the 709 hooked to it. After 10 hours it ran better than ever.
My question is: the book with the 709 says to set the rockshaft selector lever to "D". When I do that, the 709 is at least a foot off the ground and the tail wheel does not make contact with the ground. It has a picture with the center link connected at the top bolt hole. That is even higher, so I have it in the second.
It worked great at that height in tall brush, but if I want to cut lower, I will have to change the rockshaft selector lever to another setting.
This is all new to me and I want to be safe and at the same time using the tractor and 709 to their full potential.
Robert
DON
06-22-2004 11:20:15
 Re: 3020 and 709 rotary cutter in reply to Robert Barcus, 06-21-2004 19:29:42
SOUNDS LIKE THE ROCKSHAFT CABLE NEEDS ADJUSTED. WITH THE LEVER IN "D" AND THE MOWER OFF THE HITCH ADJUST THE CABLE UNTILL THE HITCH JUST GETS TO THE TOP, THEN IT SHOULD BE OK UNLESS THE L&D ADJUSTMENT INSIDE IS OFF. DON
Robert Barcus
06-22-2004 19:31:25
 Re: Re: 3020 and 709 rotary cutter in reply to DON, 06-22-2004 11:20:15
Thanks Don.
What really puzzled me was that it would sometimes be alright. Then the very next time, it would act up. I took off the side cover under the seat and the problem was the cover was putting the cable and rockshaft lever in a bind. But not every time. I left out the bolt on the cover next to the fender and all is well.
Thanks, Robert
