In theory it's easy, and actually if the wheels have been moved in the last few years it is. However....if they havn't been moved in the last few years they can be a real bear, as not only are the bolts rusted tight, but so are the wedges and the hub to the axel. The idea is to loosen/remove the 3 bolts on the wedge, and then tighten the 2 jack screws in to move it off the wedge and then with the teeth of the axel up, rotate the rack and move the wheel in and out. Which works if everything is loose. Have long cheater bars handy to move the bolts and at least 3/4" sockets. Tricks I have heard: Loosen the bolts and then drive the tractor around and apply the brakes to one tire or the other. (havn't tried this) Some say use a torch to heat it up, others say don't. If you do it takes a lot to do any good as the castings are so big. Tighten the jack screws in as far as they go, and then hit the end of the axel with a big sledge. Then tighten the jack screws so more and back to sledge. When it breaks free of the axel, you'll hear the tone change. (this actually seemed to work) Loosen the three bolts and then pound on them directly to get the hub out. Lots of penetrating oil. Good Luck! Took me a month to move the ones on my 60. Andrew
