Diesel Fuel In Motor Oil on J.D. 720
Warren
06-21-2004 07:16:45
I have a 1958 J.D. 720 Diesel (serial # 7216924)
and I see fuel starting to get in the oil. I check the oil on the dip stick when I let it sit for a week. It stays the same on the dip stick, but when I run it for an hour or so it starts to inch up on the dip stick. Is there any special place to check or is there a more common place to check for a leak? I would appreciate any comments or answers on this subject.
Thanks,
Warren
Clooney
06-21-2004 08:58:13
 Re: Diesel Fuel In Motor Oil on J.D. 720 in reply to Warren, 06-21-2004 07:16:45
Warren, the usual place is a cracked injector line or a loose internal injector line fitting.. While there is an off chance the transfer pump in the problem there is a weep hole in the bottom of the 720D-730D transfer pumps that is supposed let the fuel drain out if an internal leak occurs. If that weep hole is plugged it could allow fuel to enter the engine.
~Probably the place to start is to pull valve cover & pump cover & look for a clean spot [leaking fuel will wash the area around the leak clean]..
~Then start the tractor & look for leaks [you can run it with the pump cover & valve cover removed].. CAUTION: don�t use your hand to look for leaks as those high pressure injector systems can inject the fuel right through your skin [use a strip of paper to check for a leaking area]�
~You might want to use a small mirror & look under the pumps & fuel rail for leaks also..
~If nothing obvious found then make sure the weep hole is open on the bottom side of the transfer pump..
Post back with any questions..
[email protected]
DON
06-21-2004 07:47:35
THE FUEL TRANSFER PUMP ON THE GOVERNER HOUSEING CAN DO IT , MOST LIKELY THE INJECTOR PUMPS ARE LEAKING AS WELL AS THE INJECTORS THEMSELVES.BEST HAVE THE PUMPS AND NOZZLES RUN AND BALANCED. DON
