Elect tach inop on a 2040, alt overcharging
John
06-21-2004 06:13:27
Anyone know where the electronic tach on a 1980 JD 2040 gets its signal? The alt puts out about 15-16volts, is the problem connected? Anyone have a wiring schizmatic diagram?
John
06-21-2004 20:40:50
 Re: Elect tach inop on a 2040, alt overcharging in reply to John, 06-21-2004 06:13:27
Well I found a bad ground wire above the batteries, now the tach works but is not accurate, getting closer.
david val
06-23-2004 03:44:03
 Re: Re: Elect tach inop on a 2040, alt overchargin in reply to John, 06-21-2004 20:40:50
tach sensor is on timing cover under water pump.
i guess high voltage can iterfere with the electronics. take care of the overcharge and check again.
david
