2440 Brake problems
Indydirtfarmer
06-21-2004 04:40:49
I asked a question about bleeding the brakes, just a few weeks ago. I tried that, and had limited results. They worked OK for about 8 hours, then got "mushy" again. There was some air in the right side, but I never got any out of the left. It looks like I might have to rebuild the brake valve. How difficult is this? I have a shop manual, and have looked it over closely. Do you need any special tools? What do I need to look for? (As far as worn parts) I have e-mailed my Deere dealer to get a rebuild kit for the job. I haven't heard back from him yet this morning. I'm assuming there is a "kit" There are no brake "shavings" in the rear end. The brakes work great right after being bled. they just go away quickly. Sounds like the valve to me. Anyone with advice, let me have it! Thanks. John
david val
06-23-2004 03:54:34
 Re: 2440 Brake problems in reply to Indydirtfarmer, 06-21-2004 04:40:49
as far as i know there is no kit for these valves in ag tractors, however there is a kit in industrial tractors pc's that fits (401c and such). if you have two expantion plugs on top of your unit, then you have to order one separately. there's only one plug in the industrial kit.
david
p.s. just found the kit in 2020 pc, AR54929.
david
WTW
06-21-2004 08:05:20
John, Do a quick and easy test before you tear into the brake valve. Disconnect the line from brake valve on the side you want to check and cap it. If the pedal is hard on the first pump and does not settle there is nothing wrong with your brake valve. If the pedal is not hard and settles the check valve inside the brake valve is not seating and is leaking causing pedal to settle. When rebuilding these brake valves, damage to the spool actuated check valve is common due to improper assembly. Not hard to work on and requires no special tools just some do and don'ts. Good Luck. DW
