Last year I inherted a 74 830 JD tractor from my grandfather when he passed away. After using it for a short time I noticed it making loud raspy noise from what sounds to be the transmision/rockershaft area. I noticed it only makes the noise when the clutch is pressed in. Yhe noise will quickly fade in 2 or 3 secs after engaging the clutch. When it is making the noise it comes and goes, and can noticly effect Hydraulic power when the noise is being made, as it can be felt in the power steering or lack of power steering. When I first noticed the noise I changed the Hydraulic filter. Sense I have went threw the whole tractor doing all the mantiance top to bottom per the Owners manual. Also the top seal of the steering colum it was leaking so I removed the seal, the seal looked perfect and soft so cleaned everything and it hasn't leaked sense and I can't find any leaks anywhere else. I inspected the Hydraulic pump nothing seams to be wrong with it and Im 100% sure the noise is not comming from it. I recently changed Hydraulic fluid, cleaned the intake screen and changed the Filter again. All this and nothing changed in the Hydraulics. althou the engine is running better. It only has 730 hours on it. my grandfather bought it new for his orchard. so the first 2 or 3 years it was used pretty decently. But soon after it just sat some years where it was only started once or twice. Other wise the tractor is prefect working order. Any help would be great, thanx all. Mike C
