Help to change Generator to alternator on a 4010
Kip
06-20-2004 23:47:55
Could someone tell me what steps I need to do to change from a generator to an alternator on my 4010 J.D. Thank you
buickanddeere
06-22-2004 12:03:18
 Re: Help to change Generator to alternator on a 4 in reply to Kip, 06-20-2004 23:47:55
There is the option of rebuilding the generator with 24V 18amp windings from a late 840 two cylinder instead of the stock 24V 10 amp windings. Equal balance the loads drawn off the batteries. And crank the voltage regulator to 28.4V measured at the batterys in cold weather and 27.6V in warm weather. Install a new pulley and belt and she should be good for years more. No wiring mysteries to solve either.
txblu
06-22-2004 09:36:04
Well,
My 4010 has a 24 volt starting system which dictates a +12v system tied to a -12 volt system with chassis in the middle. So the starter, gen and voltage reg are 24v and the rest of the tractor is wired off either +12 batt or -12v batt. If wired correctly, both loads are equal so that the battery drain will be equal and when the 24volt charger kicks in, both batteries get equal shares.
I know at least the fuel gauge is wired -12v but not sure as to the rest.
I assume you are wanting to get a GM self contained regulated 12v alt?
Might want to re-read this reply and think about that. If you have a 24 volt alt located that is inexpensive then the "price of poker" may be reasonable.
Mark
