Don't be too surprised to find that the temp gauge isn't working. Technically speaking your best bet is to use a thermometer and measure the coolant temp at the radiator. There could be a couple of reasons for you not seeing any movement on the temp gauge. First, it might be broken (mine was when I got it). Secondly, there were two types of cooling systems for the 50. The early one did not have a conventional automotive-type thermostat. Instead it used a set of shutters in front of the radiator. There was a special type of thermostat that moved an arm to open the shutters when the coolant temp got hot. These systems tended to have problems with the shutters and linkages rusting up and not opening. Lots of owners simply removed the shutters and ran an "open system". The later cooling systems used a conventional automotive-type thermostat in the cooling system that does not allow water to flow until the engine warms up. This is a much better system as it is not only free of mechanical linkages, it allows the engine to get up to temperature much faster. The early shutter system requires you to heat all the coolant (7 gallons!). If you have the early type of system you can change it over to the newer system but you will have to change the radiator castings and water pump. I seem to recall that there were two variations on the later system in which one put the thermostat in the casting that sits on the head. I don't remember for sure but I'd be happy to look it up in the parts book if you send a reply to this message. Now, how do you know which system you have? Remove the nose cone by removing the 6 bolts that go around it. It just lifts off. The screens are part of the nose cone if you ever need to replace them. If there are shutters on the front of the radiator you've got an older system (like mine). If you don't see any shutters look on the bottom casting on the front of the radiator to see if there is a thermostat that has (or had) a mechanical arm sticking out of it. If you see that, then somebody removed the shutters. If you don't see the shutter-type thermostat then you've got a later type system. While you have the nose cone off, check the air intake horn located on top of the radiator. This gets dirt, hay and wasps nests stuck in it. I ended up making a simple lever system for my shutter system that I open when the engine reaches operating temp. Eventually I'll make a cable system that I can control from the seat. I'm not sure about the newer style systems, but the older shutter system will take some time to heat up. If the shutters are missing you may wait some 30 minutes idleing before the temp gauge shows much movement. Running under a load will obviously warm it up quicker but even then if you don't have shutters I can run my 50 around with the mower and never see more than 140 degrees. The engine is designed to run around 190-200 degrees. Running at lower temps tends to contribute to spark plug fouling and does not heat the oil fully enough to remove condensation. My 50 does not run nearly as well cold as it does above 140 degrees. If you don't have them already, I'd recommend both the John Deere Service Manual and the John Deere Parts Manual (both available in reprint form from John Deere). I think the owners manaul is worth having too. There are lots of places where you will have to put this kind of oil and that kind of oil etc. I also tend to use the free online John Deere Parts service to look up the availability and relative cost of various parts. The 50 is a great little tractor. I'm very fond of mine. Good luck with it and drop me an email if you have any questions. John 1953 Model 50.
