It's very common for the electromagnetic clutch coils to partially short out and draw too much current. I don't have the spec for yours, but I think most are around 5 amps, which gives you a wide margin with the 15 amp breaker, and if it was tripping that it has probably gone to coil heaven. Maybe you also fried the switch with your 20 amp fuse. Troubleshoot by using a jumper wire (engine OFF for safety!) from a 12 Volt source (starter solenoid?) to the clutch wire, and see if the clutch "clicks". If it does, it would be good if you had access to a meter capable of measuring the DC amps the clutch is drawing while "hotwired". If you take off the clutch and/or replace it, be sure to set the air gap to spec (with the nyloc nuts that adjust the brake plate in or out on the studs with the springs on them). If this is set wrong, you will burn up the clutch in short order. According the the jdparts website, it doesn't look like you can just by the coil anymore, it looks like you have to buy the whole clutch for about $160.00.
