40T Engine Block
Moose
06-20-2004 15:44:13
I just bought a very nice 40T that had just been gone through 4 years ago, engine rebuild by reputable John Deere dealer, new tires, new paint, etc. Then due to circumstances it was parked without any antifreeze in the coolant. The engine block froze and cracked the block. We started the tractor with no problems and quickly ran it through the gears. All worked fine. My question is, does anyone have any recommendations on where to get another block. I have been warned not to get one with a sleeve due to the lack of a water pump on these tractors (thermosiphon?). Any help would be appreciated.
Henry J
06-21-2004 11:02:16
 Re: 40T Engine Block in reply to Moose, 06-20-2004 15:44:13
Moose
While you are shopping you should give John Shepard a call 715-265-4988
Shipping may be the challenge, but it was not uncommon to see a pallet with an old motor strapped to it go thru the terminal of the Freight company I once worked for.
buickanddeere
06-20-2004 20:59:01
The block is as common as dirt and should be priced right. The same one is used on the M,40,320 & 330.
Moose
06-21-2004 18:11:35
 Re: Re: 40T Engine Block in reply to buickanddeere, 06-20-2004 20:59:01
I thought that the 420 and 430 were .250 larger. Are there any other differences?
buickanddeere
06-21-2004 23:08:24
 Re: Re: Re: 40T Engine Block in reply to Moose, 06-21-2004 18:11:35
There are 250 thou larger bore in the 420/430/440gasser's than the M/40/320/330 block. Different water jacket/water pump provisions too.
ralph
06-20-2004 17:21:50
where do you live? i have several in SW OREGON. ralph
Moose
06-21-2004 18:09:50
 Re: Re: 40T Engine Block in reply to ralph, 06-20-2004 17:21:50
I live in Vicksburg Mississippi. I understand that they can be shipped UPS since they weigh less than 150 pounds. I have unlocked my email. If you want to get rid of one, let me know how much you want for it. Thanks for replying.
