DLTX 81 carb on a Deere 520 Wrong?
Ted YB
06-19-2004 21:40:53
I just purchased a 520 John Deere with a 45 John Deere loader on it. I plan on using the tractor for projects and attaching 3 point rear snow blower to the tractor. When I first got the tractor, gas came out of the carb around the bowl, missing gasket, high float, and little blow back in the intake. I cleaned up the oil pressure sediment bowl, added a carb bowl gasket. Of course, the crankcase became a mixture of oil and gas. Drained and install new oil and filter, and reset the carb float to 0.5" from the gasket to the center line of the float. I noticed the carb was a DLTX 81, manufactured in 9/54. This tractor, 520, came out in '56 through '58 and a little research brought out the fact the carb should be a DLTX 99. Is there any differences that would cause my 520 not to work with the DLTX 81? I am still having problems starting and keeping the engine running, playing with the choke and such. I am going to make sure the fuel to the carb is not restricted, it was nearing not flowing at all with the sediment packed full of dirt on top of the bowl screen. It seemed like the engine ran fine until the gas in bowl ran out. Not now.
buickanddeere
06-20-2004 11:33:28
 Re: DLTX 81 carb on a Deere 520 Wrong? in reply to Ted YB, 06-19-2004 21:40:53
The Model 81 carb bore and throttle plate size was used on the 60/620/630/70/720/730. A bit much unless the 520's engine has been wildly bored/stroked/over revved for pulling.
Duane Larson
06-20-2004 10:01:51
Ted YB,
As Earl noted, you have the wrong carburetor - it is designed for a larger engine than yours, but it will work on your engine at some level.
The proper float level setting is given by JD as a distance of 3/4" from the bottom of the float to the bowl gasket groove (without the gasket in place and the carb turned upside down). However, a more accurate way to set the float is to remove the bowl drain and insert a 1/8" NPT hose barb, with a length of ~12" clear plastic tubing pushed over it. Hold the plastic tubing along side the carb, turn the fuel on, and the fuel level in the tube will mirror that in the bowl. The fuel level in the bowl should be close to the bowl gasket. I set the float so the fuel level is < 1/8" below the gasket.
Setting the fuel level by measuring the float position depends on the correct needle and seat being in place - and that is not always the case. The carb was designed to operate with a particular fuel level.
It is possible you have some plugged passages in your carb, causing operational problems. Doing a search here for duplex carb repair will turn up LOTS of info on what to do.
Earl S.
06-20-2004 09:41:30
Your DLTX 81 is for a 60 gasoline serial # 6000001 up.Taken from John Deere Service Manual SM 2024. Earl In Illinois
