4320 Knocking
G Thibodeaux
06-19-2004 20:49:35
To make a long story short, my 4320 was running good but developed a bad knock right after I rebuilt the injection pump. So I took the oil pan off and found some bad crank bearings and rod bearings. But some of the crank shaft bearings had turned. The tractor is old and I don't want to spend a lot of money to tear down the engine. I'm thinking of putting some new insert bearings back in but I could use epoxy to help hold them in place and act as a shim to make up for slack. Then I could drill a hole through insert and cap and tap in a small alluminum dowel to prevent inserts from turning again. Maybe I should put dowels in all the bearings. Any comments? Remember, I am trying to repair this tractor as cheap as possible.
Jaketh
06-21-2004 18:27:09
 Re: 4320 Knocking in reply to G Thibodeaux, 06-19-2004 20:49:35
Who would want to buy a tractor with such mickey mouse "repairs"???
Would you like to buy a tractor that has been "repaired" as you describe?
Don't make it into a bigger pile of scrap than it already is.
Ralph
06-20-2004 14:24:14
I would say repair the tractor properly or don't repair it at all. If the new bearings want to spin they will make short work of any glue or aluminum pins. Why would you want to drive a tractor with epoxied or Al pinned bearings? If your intent is to sell it to someone else, I would set aside a good portion of the sale price to retain a good defense attorney. Selling it "AS IS" will allow you to keep whatever money you get for it.
DON
06-20-2004 07:27:19
WELL YOU KNOW BY RIGHTS THE BLOCK SHOULD BE LINE BORED. HOWEVER HOW MANY TIMES DID THE BEARINGS SPIN. CAN YOU STILL READ THE NOS. ON THE BEARINGS? IF SO TRY A NEW BEARING IN THE BLOCK DOES IT FIT TIGHT? IF SO IT IS PROBABLY OK, BUT IF ITS LOOSE THEN YOU BEST BITE THE BULLET. WHAT DOES THE CRANK LOOK LIKE? WHY DID THIS HAPPEN IN THE FIRST PLACE? BAD OIL PUMP, LOW ON OIL??
