JC, due to probable wear & the fact those D's are prone to leakage I would recommend 140 weight gear oil [preferably GL-1].. 85-140 gear oil is NOT 140W gear oil.. It is 85 weight gear oil that doesn't thin out any more than 140 weight would at high temps.. I doubt you would ever work that D hard enough to raise the gear oil temp enough to ever see anything except 85W.. Also the 85-140 is an energy saving gear oil that flows easier & is less clingy than the old GL-1 mineral type.. ~There isn't much in that old D that a high EP content gear oil would hurt [probably the reverse idler gear bushings] & even then damage isn't a fact, just a possibility if conditions are right... ~If you aren't going to use that D in cold weather then I would highly recommend 140 weight gear oil.. ~I would also recommend you only put 5 gallons in [that's all I use in mine].. 5 gallons will be plenty if you don't work that D on severe side hills.. With just 5 gallons that will keep the oil level slightly below those axle housing seams & will pretty well eliminate the seeping from the axle housing joints.. ~You shouldn't have any problem finding 140 weight from your local bulk oil supplier or machine oil supplier.. You can even order 140 weight on line.. ~If you just can't find 140 weight gear oil & must use something else you would be much better off using straight 90 weight. I don't know about your area but in mine Wal-Mart has 90 weight GL-1 in 5 gallon pails for under $25.00.. [email protected]
