Engine trying to run away!!!!
Wes
06-18-2004 20:03:31
I got the 47 A out today to do a little plowing. Drove 4 miles to my grandpas house and it ran fine. Started plowing and everything was still fine. After awile I had to shift so I stopped and the engine started to rev way up. I pulled the throttle back and it wouldn't settle down until I pulled the throttle all the way back then it died. I had it set so that running full throttle out of gear with the clutch lever engaged it ran at about 1050 rpm and idle was about 450-475 rpm. I just had the carb rebuilt last year and have only put about 20 hours on it. I think it is the governor but would appreciate any and all advice I can get.
Wes
P.S. While under a load it runs nice and smooth.
Ralph
06-19-2004 18:33:10
 Re: Engine trying to run away!!!! in reply to Wes, 06-18-2004 20:03:31
We had a '46 A that had the same habit. Since I was young and green at the time, I'm not sure what caused the problem. Occasionally when one hit some tough going at the end of the field, i.e. 8' CC field cultivator, lifting the impliment would set her off. Our remedy was to pull the choke full out. With a stiff breeze on a spring day one could send a white plume (was a two fuel on distillate) half ways across an 80 rod field. I do know that it had not tossed a gov weight.
Bob
06-18-2004 23:00:53
You may have lost a governor weight.
Duane Larson
06-18-2004 21:25:12
Wes,
Scary! First, I would check the governor linkage from out of the governor box all the way to the carb butterfly to make sure nothing is sticking or hanging up. Sometimes cotter pins can get caught. With the tractor not running, push the throttle lever through its full range and look for any signs of binding.
If that all looks good, unhook the governor rod from the carb butterfly, and holding on to the carb butterfly have someone start the tractor. Then slowly open the butterfly with one hand, while holding the governor rod you just unhooked with the other. As the engine speed changes, check for smooth back and forth operation of the governor rod. If it does not seem to operate properly, post back with the results. It sounds like you could have a governor problem if there is no linkage problem.
If the carb was rebuilt, I suppose the throttle place could have come loose, but other than that I can't think of a carb problem which would cause the run away problem.
