3020 oil leak at trans filter housing
Robert Barcus
06-18-2004 18:58:45
My brother and I just finished changing the trans/hydraulic fluid. Unfortunately, some of the parts from the filter housing fell into the drain bucket. We are guessing that the spring goes onto the bolt followed by the bellshaped keeper that holds the filter in place. Inside that there is a washer and o-ring. Then a circlip holds everthing on the bolt.
Only thing is, it leaks like a seive. At the bolt hole and the back of the filter housing.
We were going to get moving early tomorrow morning, now I think we will have to wait until the dealer opens to look and the microfiche.
Any suggestions???
Robert
Believer45
06-18-2004 20:08:07
 Re: 3020 oil leak at trans filter housing in reply to Robert Barcus, 06-18-2004 18:58:45
If you will go to the site in the link below, register you will have access to parts manuals for all JD tractors. Look on the home page, upper left edge, and you will see where to register. Once registered, log in and you can go by part number, use, model number - it is very useful. It will also get you a blowup view of what you took apart.
Dave / Believer45
