James, That info is not in any JD literature I have because the Uns L used a Hercules NXB engine with an Edison Splitdorf magneto. However, I think the principles are the same, so here are the instructions for timing a Wico C909 magneto on a styled L with a JD engine.Loosen the timing cover and rotate it out of the way. Turn crankshaft until SPARK mark on flywheel lines up with mark on edge of timing hole. Remove the distributor cap (the one held on with 2 screws) from the magneto. Rotate the mag gear CCW (viewed from the gear end of the magneto) so the rotor button arm is at 10:00. Then rotate a small amount CW until the points JUST open - the arm should then be about 8:30. Hold the magneto and rotor button in that position, and engage the magneto gear with the engine gear. As you push the mag into position the arm will rotate as the gears are helical. Bolt it in position. Now check the timing as follows: rotate crank (and magneto) CW until the magneto impulse occurs, then rotate CCW until the spark mark shows in the timing hole. The points should just begin to open at that point. If not, loosen the mag and rotate it until they are JUST opening, then bolt it back down. As you rotate the engine CW, the DC mark on the flywheel should be at the lower edge of the timing hole cover when the impulse trips. These marks are for the #1 cylinder (closest to the radiator), so you may have to rotate the engine through the #2 cylinder operation to see the DC mark. I am assuming the SPARK and DC marks are on your flywheel, and in the same position as on the later L flywheel. If this doesn't work, post back and I will go look at my unsL and figure it out.
