116 jd lawen tractor
dthomas
06-18-2004 11:03:32
We bought this tactor and then the engine went. now the hydo drive would get weak when hot. We drain the oil and tried to replace the oil and it only will take about an oz. Like an air block. How much oil does it take ? The book says to use 20 w.moter oil. Is there a trick getting it to take oil?
Thanks for any help.
Dave
Don
06-18-2004 20:26:53
 Re: 116 jd lawen tractor in reply to dthomas, 06-18-2004 11:03:32
I had the same problem and was advised to jack up one rear corner and then ad the oil slowly. If my memory is correct I think I also discovered that if I pull out the freewheeling control it sped up the process of refilling. I finally sold mine as it would vapor lock when warm and the charging system was a joke. Good luck, Don
