70 gas ignition
Oppy
06-18-2004 09:14:16
I've got a jd 70 gas which we recently installed an electronic ignition. The question that I have is that do I need to run a resistor? We had one before with the conventional system but how can I figure if I need the resistor with the new electronic ignition?
John T
06-18-2004 15:56:48
 Re: 70 gas ignition in reply to Oppy, 06-18-2004 09:14:16
Oppy, whether or not you need a ballast resistor depends on what voltage coil you use. The electronic switch simply replaces the old mechanical points switch, it doesnt affect what coil or ballast you may be using. Therefore, if you had a 6 volt coil and a ballast resistor,,,,, ,you would still use the ballast to drop 6 volts leaving 6 across the 6 volt coil. NOTE if the unit itself requires a 12 volt hot feed, such should come from the IGN output of the ignition switch or ahead of the ballast, NOT after the ballast which is dropped to 6 volts.
To get the most bang for the buck from that elec. switch, I always highly recommend you couple it with an after market high energy high performance coil and you can go ahead and use a 12 volt and have no need for any ballast after that. Also, you can run a wider plug gap using that high energy coil for a real hot good spark.
Sorry I took a while, I just returned home been gone. Post back or e mail [email protected] any questions about your new ignition.
PS check with any high energy coil vendor about their plug wire recommendations. With that switch and a wider plug gap you can be running at higher firing voltages than you used before, so you gotta have good wires and caps n rotors etc.
Let me know, Good Luck n God Bless ya Oppy
John T
Oppy
06-21-2004 07:54:54
 Re: Re: 70 gas ignition in reply to John T, 06-18-2004 15:56:48
John T,
Thanks for the help. We've got the hot coil and it will be installed and wired per your suggestions. A couple of more questions for you, what plugs would you recommend and what would be the wider setting to run them at?
Clooney
06-18-2004 09:38:10
Oppy, it depends on the coil mostly..
~On all the E.I. systems I�m familiar with the actual E.I. hall effect module runs at battery voltage so obviously no resistor needed there.. Now on the coil, a lot of the later tractors used a 6 volt coil on a 12 volt system then used a ballast resistor to drop the running voltage to 6-8 volts to protect the points from burning [not a problem on an E.I. system.. That resistor also helped the coil to live longer..
~So to answer your question,, the 70 gas [IF it has the original coil] used an internally resisted coil so on that tractor no resistor is needed.. If your tractor had a later 6 volt coil with ballast resistor then it should still use a resistor to protect the coil [again, depends on the coil]..
~There are a few ways you can determine what your coil needs..
*The first is to use an ohmmeter & measure between the 2 little primary terminals on the coil [if much under 3 ohms then a resistor probably should be used].. If over 3 ohms then no resistor required..
*Next would be to use the tractor at low RPM�s for a while & lay your hand on the coil [if the coil is too hot to touch then a resistor is probably required]..
*Another way is to just use the tractor & see if the tractor stays running.. Usually if the coil is powered to high the coil will overheat & shutdown after a while..
~Remember�IF you use a ballast resistor in the power wire to the coil to BE SURE the power going to the hall effect module is taken PRIOR to the resistor [that module won�t work correctly if used at a resisted power]..
[email protected]
Oppy
06-18-2004 11:41:48
 Re: Re: 70 gas ignition in reply to Clooney, 06-18-2004 09:38:10
Clooney,
Thanks for your help.
You bring up a couple of items that I should have posted in my original message.
1. Currently we're running the original JD coil with a resistor.
2. I have purchased a Petronix High Performance coil.
We are planning on swapping out the two coils.
