Help Installing JD 40S Oil Pump
Nutnbutoyz
06-17-2004 20:30:27
Should have read the shop manual first! I now see that I need an oil pump timing tool to reinstall the oil pump. I heard there is a method to reinstall pump without the tool. Any help?
Clooney
06-18-2004 03:16:25
 Re: Help Installing JD 40S Oil Pump in reply to Nutnbutoyz, 06-17-2004 20:30:27
Nutnbutoyz, you can install that pump & drive gear without a timing tool, it's just much easier with the tool..
~To do it without the tool you can install the drive gear on top of the pump then push the pump & gear up in the hole while watching the position of the distributor drive slot.. You will have to start with it off-set a little as the gear will spin as it engages the cam gear.. You can also put a big screw driver in the distributor drive slot & kind or pinch the drive gear between the pump & screw driver so you work the drive slot into the proper location by working the pump up & down until the upper shaft gear disengages the cam while turning the screw driver..
~Basically without the proper tool you will have to install the drive gear then look in the distributor hole to see if you have it correct.. If it�s not correct drop it out & try again until you get it correctly installed. Watch as that distributor drive slot as it is off set to one side so make sure you get the off set to the correct side. The drive slot runs fore/aft when installed correctly but I can�t remember if the off set goes in or out [it�s in your manual]..
[email protected]
