47 A pull in the wheels
Michael
06-17-2004 17:12:50
I finally got the wheel hubs loose from the axle and pull all the way to the end. How do I push them to the inside so I can get it on a trailer?
Thanks for the idea of using a hydraulic jack as a puller, it took a lot of time and some heat but finally broke both loose.
Jon
06-18-2004 13:50:55
 Re: 47 A pull in the wheels in reply to Michael, 06-17-2004 17:12:50
I have used a combination of all the suggestions, except the side hill trick, since we dont have hills in South Florida. I used a come-a-long between the wheels across the back, blocking the cable away from the back castings. Then after winching the heck out of a particularly stubborn "G" rear wheel, used a big sledge hammer hitting against a very thick steel pipe held on the opposite side of the hub to transfer the shock. After it moved a little, I just kept taking up on the hand winch until it was moved in enough to fit on the trailer.
Clooney
06-18-2004 03:56:02
Michael, first take all the advise below about cleaning the axle splines & hubs to heart.. The axles & hubs must slide pretty easily or you will encounter binding..
~Once the wheels will slide on the axles then I have found that just jacking the wheel/tire off the ground slightly then using your foot wedged between the tire & ground to push the bottom of the tire towards the tractor,, then using the palm of your hands to pound inward on the top of the tire will usually move the tire/wheel in pretty easily..
~If they are stubborn just drive the tractor to a side hill,, turn the tractor so the side you want to move in is down hill,, then loosen the hub clamp & drive the tractor a short ways while watching the wheel move in [sometimes forward & reverse will help]� When the wheel moves in to where you need it, stop & tighten the clamp..
[email protected]
JD-Tractor
06-17-2004 19:18:11
Loosen up the hubs and spray the axles with DURALUBE and with one wheel a small ways off the ground push in on one side of the tire and have someone bump the other side of the tire with the biggest sledge hammer you can pickup.Have a B with loaded tires and this works well, mine is a show tractor. the duralube is the key.I can push them out myself by just bumping one side with my butt.
Mike M
06-17-2004 18:32:26
One way to get them in but not on a show tractor as it will skin up the paint, is to jack up one side loop a chain around the axle housing then fish it through the slots if you have cast centers keep it equal then rotate the tire by hand this winds up the chain and pulls in the wheel.
