730DES-ignition switch
Steve
01-29-2004 10:11:09
When I touch the outside of my ignition switch with circuit tester it lights up the tester. Is this normal?
Clooney
01-30-2004 03:44:34
 Re: 730DES-ignition switch in reply to Steve, 01-29-2004 10:11:09
Steve, that sounds normal if you are testing from either terminal A or B to the switch case, or from either 12 volt circuit to the switch case.. If you are testing from somewhere else to the switch's outside let us know from where to where...
[email protected]
Steve
02-01-2004 13:05:49
 Re: Re: 730DES-ignition switch in reply to Clooney , 01-30-2004 03:44:34
I just used a test light grounded to the dash frame.
joe
01-29-2004 12:00:40
bad ground
