720 stopped moving
Carl
06-17-2004 14:51:23
While disking with a 720 gas the tractor stopped moving. Clutch was engaged, pulley was turning as was the clutch driver. I disengaged the clutch, the pulley stopped, engaged the clutch and the tractor took off just like it is suppose to. It did this 2 or 3 times before I took it to the house. It didn't make any strange noise just stopped. Anyone got a clue????? ????
Clooney
06-17-2004 15:52:04
 Re: 720 stopped moving in reply to Carl, 06-17-2004 14:51:23
Carl, next time it happens look to see if one or the other axles are turning in the wheel hubs [maybe you sheared a hub key]..
~Then look to see if either brake drum is turning [that will tell you if the lack of drive is ahead of, or behind the final drive area..
~Next I would suspect the transmission under/over drive worked out of engagement & re-engaged once the drive power stopped.
~Let us know what all quits turning next time it happens & what gear you were in.. We also need to know what trans gear sets you have in the trans [where is 1st gear in the quadrant? Top left or first notch down on the right?
~Other than that you could have a gear problem in the counter shaft idler area or a slipping pulley drive gear or sheared key in the trans [depends on the gear you were in]..
[email protected]
Carl (for Clooney)
06-18-2004 15:55:32
 Re: Re: 720 stopped moving in reply to Clooney , 06-17-2004 15:52:04
Well took her back to the field. The tractor will stop moving in 2nd and 4th gears. 1st and 3rd seem alright. 1st gear is top left of the quardent. When it stops if you disengage the clutch and knuckle it back in it takes right off. Might go 10 feet or 300 feet before it stops again. It does make a noise like gears trying to mesh. But that stops when you disengage the clutch. The brake drums and axles are not moving when it stops.
buickanddeere
06-19-2004 08:26:29
 Re: Re: Re: 720 stopped moving in reply to Carl (for Clooney), 06-18-2004 15:55:32
If you keep trying to operate the tractor when there is a known failure. It's just going to repair more expensive are other components getruined. Maybe into a set of gears/shaft as well now, when only bearings or shifter adjustment could have repaired it.
buickanddeere...grammar d
06-19-2004 13:37:20
 Re: Re: Re: Re: 720 stopped moving in reply to buickanddeere, 06-19-2004 08:26:29
If you keep trying to operate the tractor when there is a known failure. It's just going to make the repairs more expensive as other components are now getting ruined.
Maybe needing a set of gears/shaft asnow, when only bearings or shifter adjustment could have repaired it. I'm going to have to watch my cut,paste and proof reading closer.
Soldier Tom
06-19-2004 08:16:50
Mine (7204404)does the same thing in 4th. My shift quadrant is set up the same way, 1st is top-left. ~Walk in peace~
