Alternator on 49 A
Nick
06-17-2004 14:20:05
Is it possible to use a Delco alternator on this tractor with magneto ignition since there is no switch? I read in an article on this site that the exciter wire should be switched in order to "shutdown the alternator when the engine is off". Is this necessary for correct functioning? Also, is it possible to install some kind of kill switch to my magneto to shut it down rather than stalling it with the throttle? Thanks, Nick
John T
06-18-2004 16:12:13
 Re: Alternator on 49 A in reply to Nick, 06-17-2004 14:20:05
Hi Nick, YES its sure possible to still use a Delco Alternator even with a magneto ignition. When battery powered coil ignitions are used, however, the hot when ON output of the ignition switch (that powers the ignition coil) simply serves as a good point to excite the alternator (like a GM 10 SI 3 wire). If you dont use an ignition switch, you can simply run a switched hot feed via an oil pressure switch as posted below from a drawing I believe Tom ?? posted for all our benefit here long ago.
Your second question is also YES, its easy to run a kill wire to a mag to kill the spark via some sort of dash mounted kill switch. The Wico X had a kill switch stud out its side which you simply run a wire to and use a dash switch so attaching that wire to frame ground kills the spark. The switch could be a momentary SPST normally open spring return push to kill switch or an ON/OFF toggle switch. Run a wire to the mag and the other switch wire to a good clean frame ground and whn you wnat her OFF the switch closes and connects the mag to ground which kills it.
If you have another mag, you can still do the same maybe using a hole and silicone sealer etc to get into the mags interior. The kill wire would attach to the points where the condensor lead does and run out and up to the kill switch. Grounding the points kills the spark.
Post back or e mail any questions and what mag you have and I can help you get both the alternator and kill switch wired up correctly. You can alo use a true one wire alternator, unlike the GM 10 SI which is a 3 wire and needs the circuit shown. They are more expensive and may not excite (kick in) till a higher RPM can be one drawback, but they still work, are easy to wire, and dotn require the excitation circuit or oil switch etc.
Let me know how I can help you, Good Luck n God bless. Sorry I took so long, I just returned home.
John T
Clooney
06-17-2004 15:28:10
third party image
Nick, sure you can.. All you need is a N/O, 2 terminal oil pressure switch from your local auto parts store & this wire diagram.. I borrowed this diagram from a gent a while ago but can't remember who so unfortunatly can't give him credit for the excellent drawing..
[email protected]
john
06-18-2004 10:11:27
 Re: Re: Alternator on 49 A in reply to Clooney , 06-17-2004 15:28:10
Why wouldn't you just buy the similar Delco "1" wire alternator from NAPA? Then you just connect it to the ammeter.
