4010 injector pump
Kevin
06-17-2004 06:03:18
I replaced the injector pump on a 1961 JD 4010 D using the Deere service manual as my guide. The maual shows the timing to be 14 degrees BTDC (flywheel) but when I installed the pump, the pumps timing marks line up at TDC (flywheel) not 14 degrees BTDC. The tractor runs fine like this but there is blue smoke from combustion under no load condition. When the tractor is put under a load the smokes goes to black like it should. Is there some other adjustment to make on the pump to have it work as illustrated or is this a typo in the manual? Note: the manual shows the timing to be at TDC for the 4020 D for the pump marks to line up. Also, is this the reason for the blue smoke or is the engine just tired and in need of a rebuild? The engine has 3940 hours on the clock. Thanks!
ET
06-17-2004 07:11:08
 Re: 4010 injector pump in reply to Kevin, 06-17-2004 06:03:18
The 14 degree timing mark was for the origonal injector pump that had no internal advance. Your rebuilt pump should have come with a tag telling you to time it at 8 degrees BTDC. To find this this unmarked spot I use a set of dividers and get the distance between the 10 and 14 mark then on a piece of paper I mark the spots and use a simple geometry consruction to find the midpoint, which is the distance for 2 degrees on the flywheel. I set the distance with the dividers and go back to the flywheel and mark off the distance from the 10 degree mark.I always prick punch the flywheel at the 8 degree point for next time. I hope this helps and isn't to confusing. The alternative is to just turn the pump untill it runs to suit you.
