3020 turbo HP???
New Generation
01-29-2004 09:26:20
What kind of horsepower do the 3020 diesels with a M&W turbo make?
720Deere
01-29-2004 14:05:04
 Re: 3020 turbo HP??? in reply to New Generation Tractors, 01-29-2004 09:26:20
I'll have to agree with twopop. My uncle has a 1965 3020 with a M&W turbo. He put that turbo on a year after the tractor was new and the dealer that installed it wouldn't turn it up past 75 hp. That tractor has over 8000 hrs on it and has held together good, but I wouldn't push much more fuel to it. More fuel would only be a waste of money as the 3020 isn't really enough tractor to do anything with the extra horses. If you need that much more umph, go with the 4020.
twopop
01-29-2004 12:55:05
around 10 more
John Jenkins
01-29-2004 10:59:15
What you would essentially be doing is turning it into a Ford. Those older 60�s and 70�s Ford tractors all had relatively small engines for their HP class but were tyurned up and turboed from the factory and many had a hard time staying together. If you need the extra power, why not find a good used 4020 or 4230?
Mike
01-29-2004 10:01:17
Not enough to justify beating the balancer and the bearings out of it,which is what happens when you put a charger on a 3020.
