730 diesel-missing on 1 cylinder
Dave
06-16-2004 20:48:16
Need some help and ideas.i bought a 730 diesel es.starts right up easy,idles great, but when you give her more throttle it misses.It has sat for for some time,no excessive smoke, or spitting oil(fuel) out the exhaust. could it just need new fuel filters? thanx for any info. Dave
Spoker
06-18-2004 15:13:16
 Re: 730 diesel-missing on 1 cylinder in reply to Dave, 06-16-2004 20:48:16
Dave Here is some thing else to take a look at. My 720 would miss on one cylinder when you throttled it up. Found a broken intake valve adjuster. The cylinder was getting fuel, was trying to burn it but it did not get enought air for a good burn of the fuel. I first thought it to be bad filters or a fuel injector or pump. Turned out to be a real cheep fix. Set the valves to .020 hot if you have to repair a valve adjuster. Sure runs better now.
DON
06-17-2004 05:23:48
FIRST THING I WOULD DO IS CHANGE THE FILTERS. THEN CHECK THE FUEL PRESSURE. IF IT HAS A HIGH PRESSURE SYSTEM IT SHOULD HAVE 65 PSI AT THE SECOND STAGE FILTER. ALSO THE RETURN FITTING IN THE FUEL TANK ADAPTER HAS A LINE THAT STANDS UP IN THE TANK TO RETURN FUEL AWAY FROM THE OUTLET, IF THIS LINE BREAKS OFF THE FUEL SWIRLS AROUND AND CAUSES THE TRACTOR TO MISS. THEN THE NEXT THING WOULD BE TO PULL THE PUMPS AND NOZZLES AND HAVE THEM RUN. PROBABLY NEEDS TO BE DONE ANYHOW. DON
Randy Varilek
06-17-2004 03:34:04
I hade the same problem with a 730 that i had. I was cultivating with it and all at once it started missing. Took it to the shop and checked everything turned out that when I was filling the tractor with fuel, a bee had flown into the tank and had been sucked into the return line and gotten down in the check valve and had stuck it open. I had no fuel pressure. In the top of the block there is a check valve for the return line. make sure that it isnt plugged or stuck open. Also, you can check fuel pressure at the transfer pump located Just infront of the pony motor mag. Fuel pressure should be 18 to 26 psi and the closer to 26 psi the better. Good luck!
Dave
06-17-2004 14:43:56
 Re: Re: 730 diesel-missing on 1 cylinder in reply to Randy Varilek, 06-17-2004 03:34:04
thanx Randy for the info, im going to change the filters and the tube going up into the tank and and see what happens and then go from there. Thanx much for the info. Dave
