520 overheating
Thomas
06-16-2004 18:38:57
I just rebuilt my 520. Now it is running hot. I t did not do this prior to the overhaul. I have removed the thermonstat and it does not help. Any Ideas???
buickanddeere
06-16-2004 20:52:03
 Re: 520 overheating in reply to Thomas, 06-16-2004 18:38:57
Is the timing retared? How strong is the coolant flow through the engine into/from the rad?
Ron
06-16-2004 20:51:00
If it is Tuned right (Timed, etc.) and coolant is circulating, it should not overheat very quickly.. Is the coolant circulating..?? The water pump should move the coolant real well, without a thermostat.. If it is, and you are sure the radiator is clean -- you have washed it out ( the air-cooling fins)..?? Is the fan slipping..??
