Generator or regulator on '54 50
Steve (KS)
06-16-2004 17:21:26
My charging system quit working on my 50. I know I have the troubleshooting info somewhere but can't find it. How do I determine if the regulator or the generator is the problem?
Clooney
06-16-2004 18:19:15
 Re: Generator or regulator on '54 50 in reply to Steve (KS), 06-16-2004 17:21:26
Steve, short & simple...
~First thing to do is verify the ammeter is working,,, to do that simply turn the lights on with the engine not running, if you show a discharge your ammeter is probably working correctly..
~Second,,, [if your ammeter is working in the above] make sure you have battery voltage at the [BAT] terminal on the voltage regulator [the battery terminal is the one with the bigger wire & doesn't go to the generator. If you don't have battery power at the regulator's [Bat] terminal post back. That [BAT] terminal MUST have battery power at ALL times.. [If I put all the trouble shooting here it will get real confusing- FAST]
~Third,,, MAKE SURE you have a good clean ground connection of the generator & regulator & the generator belt isn't slipping.
~Forth,,, polarize the generator--To do that just momentarily run a jumper wire from the regulators battery [Bat] terminal to the generators [A] post {larger of the two}.. You should see a small spark & if so it's polarized. Now try the tractor to see if the generator charges, if not go to #5.
~Fifth,,, [If you have battery voltage at the regulator, & good grounds ] , just start the tractor & run at fast idle, then use a jumper wire & short the [F] post {smaller of the two} on the generator to the generator's case,,, If it charges then you have a bad regulator, or open in the wire from generators [F] post to the regulator�s [Fld] terminal, or a bad regulator ground.
~Sixth,,, If it still doesn't charge, leave the [F] post grounded, then use a jumper wire & jump the [A] post on the generator to the [Bat] terminal on the regulator,,, if it charges then you have a bad regulator, or open in the wire from the generator's [A] post to the regulator's [Gen] terminal].
~Seventh,,, if it still doesn't charge you can do a generator motoring test.. To do that just remove both wires connected to the generator & remove the generator belt,, Then re-ground the [F] post to the generator frame, then run battery power from the regulator's [Bat] terminal to the generators [A] post,, the generator should start to motor, then REMOVE the ground wire from the [F] post, the generator should speed up, if so the generator is probably good.. If the generator doesn't pass the motoring test post back for directions on repairing the generator [let me know exactly what it does on the motoring test?]
~It helps to print this test sheet out & take it out to the tractor while working on it..
[email protected]
