Pony Motor Oil Drain Back Holes
720Deere
06-16-2004 14:19:19
There has been some question in the not too distant past about being able to enlarge the oil drain back holes in the head and block of a pony motor. It doesn't appear to me that you could gain much on the block as the holes are very close to the sleeves. I think much increase here would compromise the head gasket.
The good news is that there's plenty of room on the heads. I believe that the existing drain holes should be sufficient on a rebuilt engine that is serviced regularly and kept clean. I think the biggest problem with oil lying around the valves is the design. They should have made a drain on each end of the block (the heads already have holes on both ends).
