B SN# 81291 main bearing question
Jason Z in MO
06-16-2004 11:31:33
I just got my crank back from the machine shop. I also left them the main bearings and rod for inspection. No machining required they polished the journals and said the bearings looked fine. They said they have a lot of life left. Of course I should plasti-guage and shim appropriately.
The main bearing shells have some visible scratches around the circumference. One you can feel with your finger nail. Are these acceptable?
Because I am questioning this, I would normally just replace them but the LH are not available from JD and the RH bearing from JD is $155!!!
Thank you for the advise!
[email protected]
