Block Removal Advice?
Greg in MD
01-29-2004 08:18:01
Hey gang,
Trying to pull the block on my '37 A and it is giving me a hard time. I got all of the bolts and nuts removed (it still has studs), and have tried using a lift to pull the front of the block up first, but I am just lifting the whole tractor that way. I have no idea if the block has ever been removed, but I doubt that it has. It has lots of dirt between the block and the sides of the frame, and I have only managed to get part of that out. I tried a pry bar between the bottom of the frame and the block with no luck.
Any of you have any other suggestions on how to get this thing off?
Thanks in advance!
Greg
Dave in GA
01-29-2004 15:08:05
 Re: Block Removal Advice? in reply to Greg in MD, 01-29-2004 08:18:01
Greg,
I had the same problem a few months ago with a '35 A. Had all of the bolts out but the frame seemed to be binding the block tightly, with dirt and rust involved. I ended up placing a garage jack with some wood beneath the block and gently raised the front of the block. At the same time, I rigged up a come-along between the block and the front of the frame and began to pull the block forward. After lots of raising from the bottom and pulling from the front, and using a pry bar occasionally, the block reluctantly came forward and upward, and was free at last.
Greg in MD
01-30-2004 04:33:59
 Re: Re: Block Removal Advice? in reply to Dave in GA, 01-29-2004 15:08:05
Great idea Dave! I hadn't thought of that.
Thanks to everyone for their advice. I guess I will try removing the bottom studs and then trying to pull it forward with a come-along.
Thanks again!
Greg
Clooney
01-29-2004 13:36:54
third party image
Greg, on the 37 A there are 4 studs sticking down from the bottom of the block & through the frame, & 2 studs or bolts going through the frame from the sides at the rear center of the block..
~You must pull the side studs if they sticking through the frame [or remove the bolts if they are just bolts].. If you want to just slide the cylinder block forward you must also pull the 4 bottom studs,, or you can leave the studs in & loosen the frame & remove the other frame to main case bolts & drop the frame enough to pull the block forward.. That requires blocking up & stabilizing both the rear case & front end [very hard if a narrow front end].. I always pull the 4 bottom studs unless splitting the tractor for other reasons... You can sometimes leave the 2 front studs in & get the front of the block high enough to clear but it is much easier if all the studs are pulled..
[email protected]
Mike M
01-29-2004 10:55:43
Greg; I did not read where you said you pulled any out from the bottom side.Was there any bolts or nuts on the bottom side ?
Greg in MD
01-29-2004 11:39:44
 Re: Re: Block Removal Advice? in reply to Mike M, 01-29-2004 10:55:43
Yes, there were nuts on the bottom studs, 4 through the frame and 3 or 4 into the crankcase. Plus the two bolts through the sides of the frame. So all of the studs still stick through the holes, which I am sure holds it together somewhat, since they are both horizontal and vertical.
Thanks!
Greg
Mike M
01-29-2004 12:48:30
 Re: Re: Re: Block Removal Advice? in reply to Greg in MD, 01-29-2004 11:39:44
Greg; I would imagine that the vertical studs going up into the block through the frame may have to come out. Is there any room to double nut them ?The block may have to come forward first and the front lifted up before the back to come out.This is how the later ones come apart. How far are you planning to disassemble?Do you have the governor and or fan shaft off ?I only ask this
because it is possible to make a splitting stand and split these more like a non 2cyl. tractor separating the frame,block,fanshaft from the main case and governor this may allow the block to be lifted up easier not having to pull it out at the same time.I have split a few late pressed frame A's this way just to put in a new block to case gasket and fix loose studs.
Greg in MD
01-29-2004 11:38:13
Thanks!
Greg
easydoesit
01-29-2004 10:11:11
Greg, I remove the dirt and get space between the block and frame all the way around then gently alternate prying front of block to frame from both sides. Being old fashioned, I work the dirt out with a hacksaw blade and an air nozzle. easy
(hope that all the bolts are out)
Did
01-29-2004 08:23:01
Did you get the bolts on frame sides out,,Try a block of wood to tap on block,,,,,
Greg in MD
01-29-2004 08:34:38
 Re: Re: Block Removal Advice? in reply to Did, 01-29-2004 08:23:01
Yep, I did take the side bolts out...
I also tried hitting it with a rubber mallet. I will give the block of wood a try.
Thanks!
Greg
