DLTX-34 Carburetor Nozzle Hole
Glenn Gordon
06-16-2004 04:49:37
I have purchased a DLTX-34 carburetor. It was supposed to be rebuilt. After having the float level flood the cylinders I discovered a clogged nozzle. I bought replacement nozzle and spring and upon inspecting the main body found that the hole the nozzle fits into is egg shaped and more than twice the size of the end of the nozzle. The nozzle is angled and I assume it is supposed to mate with the main body to prevent fuel from bypassing. The tractor idles good but any movement seems to flood the tractor out. How can this be repaired. Is there a compound that can be mixed and placed into the main body and them re-machined. I have the capability to machine the main body. I see no way of welding this as to the close clearence. Also, if I lower the float it seems to be running out of fuel. Any help is greatly appreciated.
Earl S.
06-16-2004 08:52:49
 Re: DLTX-34 Carburetor Nozzle Hole in reply to Glenn Gordon, 06-16-2004 04:49:37
Glen, I would emagine that sometime the nozzle was stuck and someone drilled it out, off center.The nozzle needs to seal at the top.For performance the nozzle height in the carb venturi is a must. You can repair as per Clooneys instructions or its possible to machine the taper at the top of the nozzle (to keep nozzle height) and slip a gasoline resistant "O" ring over nozzle.The spring at the btm will hold tight and seal it off.If the hole in the carb is uneven you might try to chamfer it a little (BY HAND) with a angle deburring tool.I have used this method of repair with no problems. Any questions email is open.Earl In Illinois
Clooney
06-16-2004 06:24:54
Glen, when you say "The nozzle is angled" what are you referring to there.. The original nozzle for the 34 should be straight.
~On that egg shaped hole? Where exactly is the hole egg shaped? If it's at a sealing area you can probably just use a good machinable epoxy & put a release agent on the nozzle, or use a plastic simulated nozzle until the epoxy sets up then pull that & install the correct nozzle.. If done carefully & the excess epoxy cleaned off you might not need to do any additional machining..
~Look at the nozzle & carb closely as the nozzle only needs to seal in a couple of place to keep the fuel from by-passing it or to keep air from being sucked in..
~Also make sure your bowl vent is open to the choke plate area as that could easily be causing your flooding & rich running problem..
[email protected]
