spitting 435
arnie
06-15-2004 07:43:40
I have a 435 that I rebuilt from the ground up. My question is, The vent tube in the side of the block spits oil, especially after shut down. Is this normal? Will it stop after break in and the rings seat up? It has less than an hour on it now.
Thanks Kevin
buickanddeere
06-15-2004 08:35:29
 Re: spitting 435 in reply to arnie, 06-15-2004 07:43:40
The vent tubes are for draining lube oil from the air boxes. It will always slobber some. It's part of the charm of a Detroit along with the screaming roar. Which pistons, injectors, valve train springs and blower seals did you use? What did you do with the valves and seats?
